STM32
https://www.kn34pc.com/forums/viewtopic.php?f=79&t=1155
Страница 1 от 2
Автор:  LZ2WSG [ 04 Сеп 2023, 08:55 ]
Заглавие:  STM32
Начало със STM32. Би било добре да се инсталират:
- STM32 Cube MX: STM32Cube initialization code generator
https://www.st.com/en/development-tools ... ubemx.html
- STM32CubeIDE: Integrated Development Environment for STM32
https://www.st.com/en/development-tools ... beide.html
- STSW-LINK004: STM32 ST-LINK Utility
https://www.st.com/en/development-tools ... nk004.html
- STM32CubeProg: STM32CubeProgrammer software for all STM32
https://www.st.com/en/development-tools ... eprog.html
STM32 - тип и характеристика според обозначението
напр: STM32F030F4P6
STM32 - Family - The family of 32-bit MCUs with ARM Cortex-M core
F - Type - F: mainstream, L: low power, H: high performance, W: wireless
0 - Core 0: M0, 1: M3, 2: M3, 3: M4, 4: M4, 7: M7
30 - Line speed, peripherals, silicon process, …
F - Number of pins - F: 20, G: 28, K: 32, T: 36, S: 44, C: 48, R: 64, 66, V: 100, Z: 144, I: 176
4 - Flash size - 4: 16, 6: 32, 8: 64, B: 128, C: 256, D: 384, E: 512, F: 768, G: 1024, H: 1536, I: 2048 KiB
P - Package - P: TSOOP, H: BGA, U: VFQFPN, T: LQFP, Y: WLCSP
6 - Temperature range - 6: -40..85°C, 7: -40..105°C
Инфото е оттук:
Decipher the naming of STM32 MCUs
https://ziutek.github.io/2018/05/07/stm ... cheme.html
Understanding STM32 Naming Conventions
https://www.digikey.com/en/maker/blogs/ ... onventions
1. model_A.jpg [ 18.71 KiB | Прегледано 21378 пъти ]
Table_1.jpg [ 22.39 KiB | Прегледано 21378 пъти ]
Table_2.jpg [ 22.32 KiB | Прегледано 21378 пъти ]
Table_3.jpg [ 18.95 KiB | Прегледано 21378 пъти ]
Table_4.jpg [ 32.35 KiB | Прегледано 21378 пъти ]
Table_5.jpg [ 15.34 KiB | Прегледано 21378 пъти ]
Table_6.jpg [ 9.92 KiB | Прегледано 21378 пъти ]
Автор:  LZ2WSG [ 08 Сеп 2023, 22:30 ]
Заглавие:  Re: STM32
Тест с прочетеното:
stm32.jpg [ 125.54 KiB | Прегледано 21358 пъти ]
STM32F100C8T6:
- Type F: mainstream
- Core 1: M3
- Number of pins C: 48
- Flash size 8: 64 kb
- Package T: LQFP
- Temperature range 6: -40..85 °C
Автор:  LZ2WSG [ 20 Сеп 2023, 00:13 ]
Заглавие:  Re: STM32
STM32CubeIDE, опити за стартиране на дебъгера.
Блинк на извод PA4 и една променлива++.
Последната е добавена в Live Expression за следене изменението й.
И не тръгва, и не тръгва, и не тръгва ... И така 15 мин.
debug_loc_var.jpg [ 123.34 KiB | Прегледано 21328 пъти ]
Променливата трябва да е глобална :).
debug_glob_var.jpg [ 115.04 KiB | Прегледано 21328 пъти ]
Автор:  LZ2WSG [ 20 Сеп 2023, 13:43 ]
Заглавие:  Re: STM32
LCD1602 и енкодер през HAL
RAM: 51%, FLASH: 43% с оптимизация по памет: -Os в "бедничкия" по ресурси STM32F040F4P6.
st.jpg [ 84.29 KiB | Прегледано 21320 пъти ]
Автор:  LZ2WSG [ 25 Сеп 2023, 11:01 ]
Заглавие:  Re: STM32
Blink към всички пинове в GPIOA и ... всички други пинове "мигат", а само PA15 "не мига".
Deja vu от 2017-та година с JTAG.
Решението оттук:
STM32F1 and JTAG disable
В
static void MX_GPIO_Init(void) { ...
добавих
  // JTAG-DP Disabled and SW-DP Enabled
  AFIO->MAPR |= AFIO_MAPR_SWJ_CFG_JTAGDISABLE;
Автор:  LZ2WSG [ 25 Сеп 2023, 14:02 ]
Заглавие:  Re: STM32
В STM32F103C8T6 20 мин се опитвам да конфигурирам вътрешните pull-up резистори за I2c. Не са достъпни.
С външни резистори работи, но ... :smt117
I can't find the PULL UP menu in STM32CubeMx. (to use i2c1)
https://community.st.com/t5/stm32cubemx ... d-p/194136
Untitled-1.jpg [ 126.42 KiB | Прегледано 20088 пъти ]
Автор:  LZ2WSG [ 14 Авг 2024, 20:30 ]
Заглавие:  Re: STM32
STM32F030F4P6 Flash memory endurance: 1 kcycle :sad
На тестовия МК сигурно съм ги достигнал. Досега не е спрял да се записва :)
Очакваш 10k поне, както на други МК, а на 030 серията - изненада: 1 kcycle
Колко са реалните?
Автор:  LZ2WSG [ 22 Сеп 2024, 13:37 ]
Заглавие:  Re: STM32
Flash и RAM: използвана памет след компилация:
Code size tips: Optimizing code size for the Particle platform
Creating /Users/rick/Documents/src/CodeSize/target/2.3.0/boron/platform_user_ram.ld ...
text data bss dec hex filename
3548 112 332 3992 f98 /Users/rick/Documents/src/CodeSize/target/2.3.0/boron/CodeSize.elf
text is the code and constant data that is stored in flash memory
data is initialized data. It uses both flash and RAM
bss is the uninitialized data. If you allocate uninitialized global or static local variables, they get added to bss
dec is the sum of text, data, and bss in decimal
hex is the sum of text, data, and bss in hexadecimal
To calculate total flash used, add text and data.
To calculate total RAM statically allocated, add data and bss.
Мой пример:
arm-none-eabi-objcopy -O binary oled_091.elf "oled_091.bin"
4764 504 1656 6924 1b0c oled_091.elf
Finished building: default.size.stdout
Flash: text + data = 4764 + 504 = 5268 / 1.024 = 5.144 кB
RAM: data + bss = 504 + 1656 = 2160 / 1.024 = 2.109 KB
Проверка:
comp.jpg [ 150.19 KiB | Прегледано 19075 пъти ]
Автор:  LZ2WSG [ 05 Ное 2024, 13:08 ]
Заглавие:  Re: STM32
Започнах да не харесвам работата и тестовете с микроконтролери на готови модули. Предпочитам кострукцията да е на платка, а за тестове: тестова платка и дори на пластмасов бредборд. Може би защото така са видими подробности за избрания МК, които в другия случай "убягват".
Снощи свързах модул с STM32F103C8T6 към USB. Не става, и не става, и не става ... Сменях USB портове, сменях кабели. Даже презапоявах microUSB на модула. От 30 пъти се подкача един път, и то с грешки. И това само към един USB порт. Отказах се от тестването: някой друг път ще бъде.
Днес разглеждам конструкции в интернет. Случайно попаднах на статия, свързана с вчерашния случай:
Programming STM32 (BluePill) Via Arduino for Beginners
The STM32F103C8 “BluePill” has a common circuit error. The pullup resistor on the USB line running to A12 should be 1K5, but is often 10K on the boards supplied. You can check this by looking at the R10 resistor on the back of the board.
Поставих паралелно 1,8 kΩ. Вчерашната конструкция заработи от раз, на всички USB портове, с всички USB кабели :). На друг модул смених резистора с 1,5 kΩ (0805, че оригиналните са много малки). "Дефектът" на готовите модули си го отбелязвам с (!) :).
41016582-2.jpg [ 261.55 KiB | Прегледано 19005 пъти ]
Автор:  LZ2WSG [ 01 Яну 2025, 14:23 ]
Заглавие:  Re: STM32
STM32 искат по-високо напрежение за HSE спрямо напр. PIC.
С наличния TCXO 13 MHz не успях да задействам STM32F031F6P6, а PIC16xxx си работеше.
Ще е необходим напр. буферен усилвател, или друг генератор.
... и някои готови модулчета-генератори "бавно тръгват". С един 25 MHz се наложи да коригирам времето >100 ms:
stm32f0xx_hal_conf.h
#if !defined  (HSE_VALUE)
  // #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined  (HSE_STARTUP_TIMEOUT)
  // #define HSE_STARTUP_TIMEOUT    ((uint32_t)100)   /*!< Time out for HSE start up, in ms */
  #define HSE_STARTUP_TIMEOUT    ((uint32_t)500)   /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
Автор:  LZ2WSG [ 02 Яну 2025, 17:03 ]
Заглавие:  Re: STM32
Днес за минутка размисъл проблемът "TCXO с ниско изходно напрежение към STM32" беше решен.
STM32 си цъка :smt041.
stm32_tcxo.jpg [ 22.23 KiB | Прегледано 18854 пъти ]
Автор:  LZ2WSG [ 02 Май 2025, 09:53 ]
Заглавие:  Re: STM32
При използване на STM32Cube, папка STM32Cube\Repository се намира в потребителската папка, т.е. на C:. Особено след изтегляне на необходимите файлове за поредно тествания STM32H7 (архив + разпакетиран архив: 5,35 GB), големината на \Repository набъбна по обем (11,5 GB).
Преместването към друг диск е лесно:
c-e.jpg [ 170.51 KiB | Прегледано 18703 пъти ]
Автор:  LZ2WSG [ 05 Май 2025, 10:36 ]
Заглавие:  Re: STM32
Добре би било да се следят обемите на две папки за потребителски настройки на средата:
При мен:
STM32Cube IDE
C:\Users\USER\.stm32cubeide\.jxbrowser-7.38.2\Profile
STM32CubeMX
C:\Users\USER\.stm32cubemx\.jxbrowser-7.39.2\Profile
Всеки ден, при всеки старт средата "трупа" 30..88..3x90...10x45 и повече mb. Затрих натрупани близо 20 GB от 7.2024 до днес :crazy.
Бе от едно време нататък ... свободното пространство на C: драстично започна да намалява ... :smt069
Автор:  LZ2WSG [ 05 Май 2025, 16:57 ]
Заглавие:  Re: STM32
Тези папки ги намирам само в STM32Cube върху win10 :smileyl:. В STM32Cube върху win7 ги няма.
Автор:  LZ2WSG [ 01 Юни 2025, 20:49 ]
Заглавие:  Re: STM32
В STM32 стойностите на повечето параметри са много по-високо от тези, описани в документацията (което ми харесва: понякога е полезно да зная възможностите на "машината" (микроконтролера)).
Преместих I2c в SYSCLK, смених единия делител с друг и честотата на I2c стана повече от 2 MHz (не намирам такова устройство за управление при мен, но само за идеята). И това е с "най-слабия" (на ресурси) STМ32F4P6.
Споменах ли вече, че в STM32 Cube всичко става само с няколко щраквания?
(Е, за тази I2c честота (извън документацията) трябваше да отворя PDF, да изчисля ръчно и да напиша стойността в i2c.c / да променя стойността на hi2c1.Init.Timing).
Някой ден ще пробвам на какво е способен за оувърклок OLED дисплея 0.91/0.96. Също така се интересувам от максималните възможности на I2c в Si5351A (въпреки че вече съм виждал стойности в други конструкции).
1.jpg [ 146.73 KiB | Прегледано 18656 пъти ]
2.jpg [ 198.55 KiB | Прегледано 18656 пъти ]
3.jpg [ 66.79 KiB | Прегледано 18656 пъти ]
i2c.jpg [ 169.77 KiB | Прегледано 18656 пъти ]
Страница 1 от 2 Часовете са според зоната UTC + 2 часа [ DST ]
